Soapy water helps as this enables you to position the rear quarter decals correctly then just squeedge the excess water out with a body filler spreader and allow to dry. The pin stripes are best put on dry. Arch decals are a pig and you might have to cut them in order to fit correctly. (Especially the front arch stripes) Top stripe should be about 1/2" below swage line I think.
Has anyone got a photo they could post of an early (1977) Mk2 Mex bootlid that would give me some idea of exactly where the "mexico" decal should be fitted?
You're right mate, İt's very hard to match the decals with the arches. I'll do them again.
to get the stripes dead straight, i always run a 1" masking tape guide along the whole lenth of the car before i start the striping - then you can gauge the distance between the stripe and swage lines better - dont be afraid to gently mark bodywork with a soft pencil for measurements - but as said, take ur time !!!!!!
