thought id start an on-goer......................
  • #16
    musta moved the pictures
    from that
    then i took out the spotwelds
    then i had a goosey inside
    nice hole, nothing a badboy welder like myself cant fix
    few more holes -
    then i got carried away and took it all out
    then got busy with the wire brush and drill
    then attacked it with some kurust
    inbetween all of this ive rewired the beige shitheaps wiring as it was bodged in about 1984 and never been put right (cellotape connecting cables and unfused 8 gauge cable direct from the battery to power a clock!) and then took it for an mot to which it passed without a hitch
    nearly done
    http://theplateman.com/ - euro/german plates
    • #17
      well, the heater bowl is all done and dusted, ive started looking at other stuff i could get on with
      so out came the wiring loom - yes, all of it, thats all the lighting, all the ignition, heater, stalks, speedo etc
      plans for that include
      new modern fusebox with blade fuses instead of shitty oldskool ones
      headliamps and spots on a relay within the fusebox
      all the vdo's, ipod charger, sub, rear water bottle, cutout switch ran into the original loom, within the shrink wrapping
      renewing of a few scabby bits of wiring and connectors etc
      isnt actually as confusing as it looks. ive pretty much had to deal with every part of that loom seperatley over the years, and i can remember what every plug does even without the labels (which i added to be on the safe side )
      • #18
        Great work
        My mk2 has gone
