Gp1 44idf carb restoration project
Found something for you in the garage last night its the proper top bracket for the dipstick tube with the correct part number on it, will give you it the next time I see you or if your through my way you could nip in and pick it up.
Andy
Clips
Hi mrwatt, really impressed with your clip making skills. Cheeky question, do you still have the tooling and if so could I buy two spring clips from you? Also can you tell me where you got hold of the RS logo and part number label (H76HF-9600-AA). My airbox needs more TLC than yours, I will also need to remake the centre threaded stud that holds the lid down in the middle. Did you go for a Wing nut or Hex in the end?
Great Resto and good pictures, they will be a big help to me.
ATB
