Not very computer savvy but I'll try some photos.A picture tells a etc etc
I've started but the finish [who knows]
Sorry pressed submit instead of preview pics didn't work. Ill have to get a computer guru to show me how
I've started with an aussie rs2000 more rust than expected cutting that out at the moment, going to put a flat front on and strengthen the shell [semi rallyprep not for comp] as the shell looks like it may have a slight kink at windscreen pillars and there's a ripple on both sides on the inside panel beside the rear seat which leads me to think it may have had a few hard landings on bitumen as the underside doesn't look to have seen much gravel and as yet no evidence of a major shunt so having a stronger shell won't hurt also with roads up here it will be more of a daily driver.I will put photos up when I can as when viewing as a guest I found other peoples very interesting and informative and it should be a lot easier and quicker than this typing .
Not happy with my mig welding buying a tig handpiece for my little invertor so hopefully my panel welds will be a bit better.
It's been a while since I played with escorts so when I get pics up please feel free to comment[besides I,m to far away to do anything if I don't like them]
All the best
Jock
picxs
5_resize.JPGHopefully some pics
Seem to only able to put 5 up
pics
9.2_resize.jpgThis Is the best I can do at present. Slow at typing so will not put much text in but if anyone has any questions please feel free to ask.
pics
IMGP2317_resize.JPGnot happy with tunnel so redoing and 1 of previous owners repair methods.
bulkhead
Tried to get pictures bigger no luck anyway bulkhead is almost finished just needs a lot of grinding and a little bog[or is that a little grinding and a lot of bog] as I had to fix rust on passengers side put gussets under rather than on top [seemed like a good idea at the time] didn't think I would need them as was going to put a cage in but the powers that be have decided that it's easier to cut a roof off and retrieve a mangled dead body from a prang rather than take a bit more time to free someone whose life has been saved by the cage but needs a bit of a hand to get out so no cages now in Qld road reg cars.
BFC seatmounts
Had to fix drivers seatmounts did not want to go rally style so mfd BFC mounts did the pass side as well just in case I need to be chauffeur driven in the future
Just got to weld underneath rear ones when back on spit and tap for m8 bolts
