Engine now on the bench. The core plug behind the flywheel looked ok until I stuck a screwdriver into it and it was wafer thin.
Gave the engine as good a clean as you can without blasting. All grease, grime and build up removed.
Isy wisy lets get busy................
Loking better for that but wether it sticks to the block long term or with the heat I just don't know. This engine is turning out to be more of an experament than anything else.
