Looking stunning Gaz,
Restoration of HWR 652T
Starting to get worried now . Car is now 99.5% finished everything is on there , all fluids in , hoses on etc just needs the cam belt putting on which martin is going to do for me as i aint got a clue how to set the timing up .
Then its fire up time and fingers crossed it will run with no leaks and everything working ok , then once its running go get it mot'd and then set up properly
so hopefully it should be back on the road by the end of june
with the engine not being run for about 2 years have you lot got any tips on what should be done before starting and once its running ?sigpic
Turn it by hand a few times before you start it.
Looks great by the way.
Only thing i would say Gaz is the outer parts of the
rear wells need blackend
cheeRS Gary...
Originally posted by FoMoCo View PostTurn it by hand a few times before you start it.
cheeRS Gary...
Yes mate, it has to go back to the bodyshop once its up and running so im going to get them to do it then .
cheerssigpic
