ford escort mk2 mex full resto
  • #46
    dav
    • #47
      sign of welds
      thanks for looking
      dav
      • #48
        A lot of work there! Nearly as much as my new one
        • #49
          That will keep you busy for a while mate.
          If you want it, get it, before someone else beats you to it.
          www.escortmk2harrier.webs.com/
          • #50
            Originally posted by Lee R View Post
            You make it look easy Davie
            Thats what i was thinking, top work fella
            • #51
              Cheers guys for comments
              Ye plenty to do
              But be worth it in the end
              dav
              • #52
                Great work as always mate, webastos cause so much rot, I have a friend with a red mex with a webasto that could do with your services!
                • #53
                  hi thanks
                  hopefully he not wanting it done for a wee while yet
                  flat out just now
                  a pm u my number
                  cheers
                  dav
                  • #54
                    update on this mex.not had alot of time to post pics due to being busy.
                    repaired needed here
                    rear repair here not finshed yet .rear panel is maybe getting removed as rear floor edge is getting thin on the ground.
                    rot here
                    some rebuilding work needed here
                    metal is thin here
                    dav
                    • #55
                      metal thin here
                      dav
                      • #56
                        chassi leg part getting some red bonda zinc primer added
                        repair needed here
                        dav
                        • #57
                          more work done
                          will add more pics soon
                          thanks for looking.
                          dav
                          • #58
                            sigpicSanity is the playground for the unimaginative
                            • #59
                              Hi folks been a while since a been on
                              Car still in progress
                              Can't gets pics uploaded due to photobucket changing there lay out a don't have a scobby how to sort it.
                              Anyone else haveing the same problem?
                              dav
                              • #60
                                I haven't been on Photobucket in ages, but I will have a look...Because I love your pictures!
