Quite a bit done today. Finally sorted the issue of the Main & Flash beams which were down to a broken wire in the loom. Sorted the bonnet catch out at last. Adjusted the bonnet pull cable, Re-wired the heated rear window, Sorted the interior light, Fixed both the air filter housing brackets on, Twisted the filler neck so the cap fits straight. Re-aligned the bonnet, Fitted the tw4t that is the glovebox. Fitted my fire extinguisher......
Few pics as of today.
Next jobs are - Fit higher front springs and lift the rear slightly. Stop the stupid cambelt cover from catching on something??????? Full nut & Bolt tighten then we'll see about the MOT.
