Originally posted by grum
Problem is that the vinyl is so taught that, although the glue sticks it, it then peels off the top layer of cardboard from the backing due to the tension. I've had one baking in the sun, I've used hot air gun to stretch the vinyl, but it's simply lost too much flexibility and size over the years. Sort of like the bulkhead pads - the bitumen there dries out and you can't reverse it.
Strangely enough, the LH side ones are all OK and the RH side ones are all knackered
