Pack it in you two. You know i'm sensitive about it
Hefty is the new slim!
Bald is the new bushy!
Cheese is the new no cheese guarenteed!
Muddy is defo the new shineeeey! (Copyright Grum 07)
Red Escorts are now Capris, thanks midlands Plod!
48's are the new bike carbs !
As said previously, that will look great in my engine bay...look after it!!
And can have 42 sq mtrs of the bottom left, plus underlay and fitting. No runners.
You can collect it with your struts
Yesterday i got the bellhousing modified and made a mounting bracket to accept the hydrolic clutch slave cylinder
Today i fitted the new 7 1/4 AP paddle clutch
Also got the engine bolted in
But the titan dry sump pan is sat hard up against the steering rack.(more problems to sort out!)
Looks the nuts . If the engines bored out to 93mm and starts making decent power and those core plugs are not bolted in then they could fly out and fry the engine so watch out for that .
Regarding your dry sump pan , it's hard too tell in the pics but it looks like it doesn't have the cut out too clear the steering rack so if that's the case then that's why it doesn't fit .
