Cheers Lee, 2008...ummmm can we talk about it Lee, i like Riviera cars it would only cost you half in fuel then
WORTHERS
I would have thought with all your expirience that you would have had some surgical grade cloths to wrap the prop in !.The state of those tee shirts you could have contaminated the prop.Don't start taking short cuts and risks at this stage of the build .
Amazing attention to detail,**** me the inside of our new fridge isn't that clean.
Could it all be to shineeeeeeeeeeeeeeeeeesigpic
thanks for your concern Graeme, unfortunetly... not. To be honest they were destined for the local hospice shop, along with three other sack loads, never worn half the stuff, so with the inpending bedroom being fitted seemed the right time to get rid, blagged a couple out of the sack when Jenny wasn,t looking Saturday morning, a lovely bright day, so i,m going to fit the shinnnnnnnnnnnnnnnnnnnnny prop today.. hopefully
Brian, i dont mind admiting, its another low at the mo, fuel tank went wrong last week, so thats still giving me headaches wont give up though, so thats holding me up, propshalf in today, hopefully, bottom hose blah blah blah, once the tank is in, prop on, i,ll then put the battery on and see what happens, if all goes well, i,ll then get in touch with Northampton Motorsport and get her booked in, carpet, seats, cone, decals, stickers, etc etc
Originally posted by grumwhats going wrong with the fuel tank then ?
my tank went in ok - took my time with it - yes there were a few head scratches, but was pleased in the end
question : do the straps you've got have a 905 number printed into them ?
trolls have, mine aint, unles its buried under the paint
as discussed before on the bb, suggest that you put some of that 1" wide thin foam between the straps and the tank - helps them bed down onto the tank
this may sound stupid, but could you use a delicate bead and turn down the pressure and have it blasted/dusted, sometimes, the material in question will come up lovely, try a bit that cannot be seen. done a couple of hard plastic items and they some up good. Being a tank obviously every thing will have to been sealed which isnt easy but ive known fuel tanks blasted before.
Originally posted by grumi tried blasting mine dave, but to no avail - just seemed to "bounce" and didnt want to risk it anymore, especially around the joint - the best way, ive found, is to use a black wax and then keep buftying
