excellant job
mk1 shell
Made up a set of brake lines today don’t know if I will use them on this car yet
Got a brand new master to go on
Going to give the discs and hubs a fresh paint
After a nice long dip in the vinegar
Nice state x member
We have a proper twincam anti roll bar for the mex but that means using proper twincam anti roll bar brackets witch we don’t have , so its out with the dill and the welder to make some
Basically the bolt holes need moving back to allow for the shorter roll bar
Extra plate needs to be added
And that’s it the caster will be restored back to were it should be
And lastly for today I made a stabilizer bracket for the air filter
White paint job and that shell is stunning
ARB back no
Got some parts back from the platters yesterday
Shinny wheel studs
I like a bit of detail I have gone to great lengths to get the correct nuts and thick washers that are fitted to mk1 escorts form new they are a full steel locking nut with no nylon in site and I had to make the washers from scratch
I used the correct UNC and UNF bolts in all the rite places
Bracket painted and it has a rubber sleeve added to stop the ht leeds rubbing thru
Cleaned the discs up
Re greased the bearings
Painted the discs in very hi temp paint
The tank is all done ready to go in
Very nice, love the roof pic!
Originally posted by LOUIE View PostLovely work going on there, sure it'll look great in the flesh...
Out of intrest I notice the ID is for an export car was there not a temptation to make it left hand drive??sigpic
