Gaz, starters are made especialy for us to fit our special flywheels.
Rs1800 replica
I thought so mate , it looked like a specialist part and not like the ones i've burnt out before , lol .sigpic 2.1 ATMO YB POWER .
I also like the coil pack bolted on the dry sump pump and the dry sump pump running off the cam belt . Much better than the 10mm wide rubber band that my dry sump pan runs on !!!!I don't dare look at the flimsey thing as it gives me the shits , lol .
Sourced a bulkhead, it's lhd but Ive had a good look and I think the bits I need will be just fine, and it's solid.
So I will piece it in carefully when I get chance.
also made myself a single light bumper after work, so I have choice on what to use.
Just needs bit more prep then powder coating.
It's been a busy week or so, finding bits and tidying things up.
tidied up the fuel tank
built up wcxm and gartrac rack
purchased decals, and a few other bits!
got hold of some early White needle clocks too
tidied up a single piece prop, new joints etc
found out some new quarter bumpers I had some years back.
Thanks mat, it's been a long time coming but nearing the end now.
Cars burried in garage in an air chamber, but as weather gets better I'll post some new pictures.
Now I have the rallycar, I need a roadcar.
Hence this new project, and compared to building the rallycar this is a lot less costly.
love the red one Wayne gorgeous.....
good work!
as for the bulkheads.....
They rust from the inside when they get leaves in them from being parked under trees which they shouldn't be!!! traditional aussie problem....
good work.Life is Racing......sigpiceverything else is just waiting
...or buftying.
