I have also changed the fpr for the filter king with the 85mm bowl with the high flow filter as the old one seamed to have failed. The new fpr even has a built in pressure gauge so so you can set the pressure correctly.
Well as my old MBE wasn't mappable by anyone in the south wales area i sold it on the bay. Then i went out and bought a DTA S40 that will control injection aswell as the ignition as i think i will either convert the webers to run as throttle bodies or run throttle bodies in the future.
I then had to set about making a wiring loom for the lot and after a lot of advise off a couple of mates i dived in and expanded my skill sets futher. After getting my hands on some top quality wire and all the plugs and plug boots i set about making it. Below is a picture of the loom half finished as i haven't got heat shrink thick enough to go over some of the wires so i will finish it when that arrives.
I am happy with the way things have turned out as i even went as far as making litlle lables and heat shrinking them into the loom. I also think the black and grey is a good contrast.
After looking everywhere for a cheaper solution i had to fork out for a brand news tps sensor fo fit on the webers as i am going to run the engine on a 3D map untill i run it on injection.
I then relised i will have to weld in a lambda sensor boss into the exhaust system to get it mapped so i will get that welded in some time this week. I am happy to say the quality of the one i got was better than the one in the picture too!
