The Black Beauty
  • is the flaps on yet?
    • Originally posted by SHIFTY View Post
      god knows, but there seems to be a lot of 'flappin around'
        which ones and where from
        • lol
          The ones from Race Andy, same moulded forest ones I got..race and ralloy do em
          They also do they ''light holders'' lol
          • Anyway, i need a rear tow Eye and wondered what to use, decided in the end to make a bracket that would fit up tight to the chassis, not hinder the 'Arc' of the leaf spring eye and not look too obtrusive, however it hat to be man for the job if required
            the chassis is in perfect condition and very solid, just need to add a small locknut behind the 'Eye' and job done
            The spring can still fully compress without touching the bracket, i only had black paint in tins hence put the paint on quite thick
            • see gj, not just a pretty face - no scrub that
              good job sir
              • Never seen snow
                despite the freeezing weather (if you are reading this in a global warmed 2050 you will be amazed to learn that the UK is in the Grip of a huge Freeze with temperatures as low as minus -20, in fact as i type it is now minus - 8 outside and it is a sunny mid morning, how cool is that ? or should i say "How Cold is that" ) ..............Anyway, where were we. Yes, despite the freezing wather i took the car out under its own power and washed the old girl down - first time the car has ever seen snow - bit like the Southampton team snigger members - now to get it back in and give it a good polishing before it (hopefully) goes away for setting up on suspension / ride height / Rolling road etc.
                For all i know, and this is actually 2050 when you are reading this, the car may still be in the garage at home (chances are i will likely be in a box underground and it wont be for a bushtucker trial), meanwhile, heres a couple of Pictures of BB out under her own power
                i bet Frosty is still spamming away.....................
                • Looking good
                  • gutters look good g
                    • Originally posted by Dave1800BDA View Post
                      gutters look good g
                      Marley Flowline (Brown) 112mm x 60mm, shifts 1.46 litres per second, with end outlet, good stuff.
                      Fascias, soffits, barge, and dry verge all replace too, all by my good self, pics to follow if enough interest. (although AndyC has stolen a march with Op Conservatory)
                      • got to admit the Safari spec suspension is growing on me
                        "stilts is the new lowered"
                        • up for alan davis
                          • Cheer Vinny,, but I managed to find it ,,, then how dissapointed,,,not a flat front .
                            Never the less a superb car , , ,
                            • Originally posted by alancdavis View Post
                              Cheer Vinny,, but I managed to find it ,,, then how dissapointed,,,not finished.
                                give him one event and i'm sure that will change
