will try and finish off the interior today and finally all the little odd's and ends underneath the car so that i can at least get the front axle stands removed
will post the pics as i go along
hopefully will also be able to fit 'Kev's' minilites
got the axle off it yesterday, easy enough, and now it is off for blasting and re coating.
have a Fostek rear brake (Disc's) to go on with the weld on brackets, new diff, and sort a few other bits out on the rear, this will also give me the opportunity to finish off grinding the welds and re coating the underside of the car (you can see how far i got with it before the axle came off)
Had RStu and Enduro up looking at it as well last night, think they liked what they saw
cheeRS[/quote]
err slight understatement to say the least,just the inside of that boot would do me!!!! after looking at yours and stu,s car,s yesterday im just glad i aint got a cat to kick coffee was spot on as well.cheers .
Axle was cleaned down today and de greased on the outside, new four link kit was powder coated and then Friday its re bush the leaf springs, new U bolts, weld the the fosstek brake kit brkts on and strengthen the axle casing, and re assemble.
taking pics along the way so will post some up soon,
