Hi , We have been working away with the shell over the last few months, i have been fussy about the inside of the car,as every hole that is not needed as been filled and every hole that is needed has been drilled,also the wiring loom has been fitted to allow any holes to be drilled before painting. Also changed the rear fire wall panel,the cage for a safety device one,and rear axle for a atlas. new door skins new front wings.now on to body work prep and painting over next few months , feels like a mountain of work at times cant wait to get the car completed so i can thrash the arse off it cheers martin
Its shaping up to be a cracker well done. In relation to fitting the rear arches are they pop riveted or counter sunk and filled in or what method did you use lovely workmanship either way
Just a wee update, inside and outside of car all joints sealed, and under side been sprayed with spray sealer and sprayed white now ready for final coat of white
