this is the new box of electronics ive had made to control the pneumatic gear shift system for the sequential gearbox,the card at the bottom does the the gearshift
the rest of the cards allow full auto flatshift up and down,8 channel datalogging with gps allows full data analysis of all connected imputs,acclerometers,launch and traction control with wet/dry settings and adjustability,rev limiter and shift lights with gear indicator
david also made this shift light and gear indicator,the shift lights flash differant sequences to indicate whats happening
i made a carbon paddleshift for the steering wheel also a switch panel for xbox controls
pneumatic control valves,solinoids,actuators and throttle blipper
ive started on fitting the wheel sensors,one each wheel
lots of things to wire so this could take a while but should be worth it
