more bits done
inner sill welded to made front and rear floors
floor tacked in a post removed and hinge panel removed
new a post inner/ outer/org hinge panel welded in place
kick panel in place
a look from inside
new piece welded in scuttle end
new front chassis leg made inner /outer/closing panel
new flitch panel made with outer chassis
well the corner had to come out
flitch panel and chassis clamped up
getting there
This guy is an absolute wizard at his work....I'm well impressed with his fabrication and standard of work. Glad to see it coming on so well for you.
Cheers, Tim.
Cheers Tim He's some operator, it's great to see the car having such an excellent standard of work being done to it. Can't wait to get up there soon and have a closer look !
Your man is a genius mate pure quality work going into that. There wont be much of the origanal metal left when its finished. Cant wait to see the end result and I take my hat off to you for taking it on.
Excellent work being done on your Mex, bet you were less than impressed when you discovered its true condition (been there) as looked a tidy car from the pics.
At least this way you know the car is right and will last.
Certainly helps finding someone with the skills and passion for these cars, sure cars are being saved now that would simply have been scrapped off not too long ago.
Cheers lads The only bit of the old car that'll be left on the front end will be the support under the slam panel As for when I realised how bad she was to say I was farting fire was an understatement. Thought I knew a bit about them when I went to look at her but I knew feck all by the state it turned out to be. It's all a learning curve sure what can you do
front chassis legs and flitch panels fitted
new roll bar tubes and end plates fitted
new cross member mounting bolts and brackets
new scuttle end made
bubble taken off and center of bulkhead and under bubble repaired
