Either someone has been messing with the settings on your camera or the sensor is on the way out....that hint of pink is very similar to when one of my old ones gave up the ghost
Push everything to the limit
if it breaks it wasn't strong enough
rebuild it and try again !
Mandy c,so talented ,im very impressed again .
Do be carefull now building it up havin the strengh of a wilderbeast and sausage fingers could make this a real task for you
Well its gone tits up so im going to strip it right back to bare metal i had problems doing the black around the windows
So the question is do i spray that black 1st then the white or the white then the black
