How you doing Andy, will need to pop along for a look,
mk1
 got the skin welded on just a last coat of filler to the pillars and some dents to fill
 also got the wings off
 o/s rail not to bad only needs small repair at front
 n/s needs new rail
 both bottom pillars had mot repairs which had to be removed or the new wing would not fit
 and the offending mot repairs
 just wating on the wing rail then I can start fitting the wings
 Andy
 he likes his blue must have a big tin of itOriginally posted by bigjohnie View Postget rid of them blue bits andy yuk
 The expreess tops are great as they cover every bit you need and saves you welding about six bits together. Drivers side fits better than the other but nothing to drastic
 Andy
