And again LOL
 Cheers for the pic, Will use that for reference.Originally posted by TimGR View PostShould look something like this after the work is done...
 Bit more done. All plumbing now done, Fuel pump moved to under the boot floor. Pedal box cleaned, painted and re-fitted. A Dave O Neil Linkage plate fitted, Filter King fitted and set to 3.3psi. Filled the tank with some Tesco 99 RON petrol as I wanted to have a quick go at starting it. Turns over but not that quickly......(Tight engine?) Didn't start so advanced dizzy slightly. Car backfired so at least that's something LOL. Will have another play tomorrow.
 Put the bobbins on but the pump sat way to low. When I first switched it on it rattled the whole car till it primed then quietened down "A little" LOLOriginally posted by Mark M View Postkev, pump should be mounted to floor via the 2 little rubber bushes.
 might vibrate itself to bits otherwise.
 looking good though.
 There is the possibility of that......Originally posted by richie View Postwhy was it too low. were you worried it may catch on the trailer.  :winka: :winka:
 Finally finished the engine bay today and am very pleased with it. Just need to put the washer bottle on but am in 2 minds whether to fit a strut brace or not??????? Oh, decisions.
 Had to chop loads out of the Servo tower for the exhaust clearance and heat shield the brake pipes and clutch cable. Going to get hot I think.........
 Originally posted by Frosticles View PostFinally finished the engine bay today and am very pleased with it. Just need to put the washer bottle on but am in 2 minds whether to fit a strut brace or not??????? Oh, decisions.
 engine bay looks amazing. well done mate.
 Need an "Inbetweeny" hole one as I have rubber roller tops fitted. Like the look of the one both Hally and Grum have. Agree, Has to be blackOriginally posted by taffr View Postget the brace on kev, make sure its black
 No chance, LOLOriginally posted by lee bishop View Postmodify it properly and fit a bias pedal box......LOL
 are you seventeen
 are you seventeen
