youve done work on that well done for keeping at after all this time
My money pit
I'm back! I'm staggered to see that it's been six years since I was last on. Since then I have retired, built an annexe to the house - and I have a new garage!
The poor old RS has unfortunately been stored outside during the building work and is a little the worse for wear (boot full of water) but hopefully I can find some time now to get on with the resto.
CHRiS
After 6 years outside, I forgot how far I was with this project so took a closer look at what I'm working with.
IMG_7153 by Chris Rigler, on Flickr
IMG_7160 by Chris Rigler, on Flickr
IMG_7166 by Chris Rigler, on Flickr
IMG_7163 by Chris Rigler, on FlickrCheers
CHRiS
First thing to address is the rear arches. They have had repair sections but they have been overlapped, not butt welded. So I cut through the arch with the intention of making a nice, strong seamless joint.
IMG_7172 by Chris Rigler, on FlickrCheers
CHRiS
Not too bad for an amateur - but still not happy. So invested in a new inner tub courtesy of Mr Magnum Panels.
IMG_7179 by Chris Rigler, on Flickr
IMG_7188[1528] by Chris Rigler, on Flickr
IMG_7189 by Chris Rigler, on Flickr
IMG_7192 by Chris Rigler, on FlickrCheers
CHRiS
This wing had been damaged at some time in its life and, when stripped, a frightening amount of filler was found. After getting it back to bare metal and a little panel bashing, it wasn't too bad but would still need filling and I didn't want that. So a sharp intake of breath and a dig into the bank account resulted in the delivery of a new full rear quarter panel.
Filler 3 by Chris Rigler, on Flickr
Filler 2 by Chris Rigler, on Flickr
25-19-51-1-2 by Chris Rigler, on FlickrCheers
CHRiS
Rear quarter stripped
Ahhh - that's better!
IMG_7443 by Chris Rigler, on FlickrCheers
CHRiS
Shut that door!
Walking trip was aborted due to the horrendous weather forecast so retreated to the garage to have a go at the driver's door.
IMG_7495 by Chris Rigler, on Flickr
The bottom had a repair on top of a repair
IMG_7472 by Chris Rigler, on Flickr
So off with the skin
IMG_7478 by Chris Rigler, on Flickr
Yuk! Pretty manky so ordered a bottom repair section from Expressed panelsCheers
CHRiS
Nasty crack
While waiting for the bottom repair section I had a look at a nasty crack in a weird place - where the inner and outer skin join under the quarterlight frame.
IMG_7469 by Chris Rigler, on Flickr
No idea why it goes here? Anyone?
IMG_7496 by Chris Rigler, on Flickr
No Choice but to cut it out.
IMG_7502 by Chris Rigler, on Flickr
Made up a new section and fixed it in.
IMG_7506 by Chris Rigler, on Flickr
Looks a bit better now.
IMG_7507 by Chris Rigler, on FlickrCheers
CHRiS
I had one in the 80’s that someone had put a big nut ‘n bolt through the door as the bracket had failed completely and there was a fatigue crack going down the skin.
Too much flex between the frame and skin. Don’t think it helps much when the top of the doors start flapping at speed.
