He Hey, got it running again.
Put 5 litres of fresh fuel in the tank and that seemed to do the trick. Just need to check I've got all the nose cone bolts and screws undone on the off side, so I can move it over to work on the near side (wish I had a double garage
). Once the cone is off I'll be able to start removing the front wings to get at the inner wing repair...then the real fun starts.
The exposed metal doesn't seem too bad, but I'll see how it reacts to my favourite de-rusting tool which is a heavy duty wire brush wheel on my angle grinder.
The wing is nearly off, just waiting for my Dremel to turn up so I can neatly cut the front edge away from the valance. The wing rail is rotten, but it seems to get solid within a few inches of the inner wing, so the replacement rail I've got should be all it needs 'letting in' I hope.
