Currently building a new dash for SKC
Still got to fit shift-light and tacho control button
alternator, indicator, high beam and oil pressure warning lamps
Fitted from left to right - All Stack components
Left lower = Oil Temp
Left upper = Oil Psi
centre = 0 - 4000 - 10500 tacho
right upper = water temp
right lower = volts
rear backing is from www.customcarbon.co.uk Carbon using an original housing - also available from Custom Carbon is an all in one backing and housing
John Selby at Custom Carbon is registered on here (custom carbon) and is open for ideas on any new products we may need him to make.
right lower = volts
