Restoration op Zebra
This topic is closed.
46
53
54
55
56
57
58
59
64
10-01-2010, 15:13
lol
but happy to put condom on his hands
10-01-2010, 15:25
That looks like you've cut far too much off
are you sure you measured it properly??
10-01-2010, 15:28
10-01-2010, 15:36
No he wasn't wearing any "Protective" glasses G
10-01-2010, 17:59
Are you any good with a welder cos looks like you will need to use one son,,PMSL.(RoddeRS)
10-01-2010, 18:29
Tes chaps cut the right lenght but now i have to grind the splines back as they hit the rear of the crank and it will not do up to the block(2.8 SPLINES ARE 10MM LONGER)
RS2kSX
Nov 2007
10-01-2010, 22:02
good luck Andy...
get some glasses
AKA The Dipstick
12-01-2010, 19:39
here you go chaps does this look better
It is 144mm from the face to the end
12-01-2010, 19:50
bit too much off now Andy
paul andrews
Apr 2004
12-01-2010, 20:52
you crazy ****er,that should be well balanced now m8.nutcase
taffr
12-01-2010, 20:54
paul andrews
does it matter on the recovery truck
Tongy
Jul 2008
12-01-2010, 23:26
NOW YOU MAKE SURE ALL IS LOCTITED AND WIRED AND GUM SHIELD ON THE READY
ON THE PLUS SIDE NO CHANCE OF YOU FALLING ASLEEP AT THE WHEEL NOW MANDY
taffr
13-01-2010, 00:03
i feel so sorry for the spigot bearing
, it'll be like a hula hoop in no time
19-01-2010, 19:20
Well took the box to pieces to get the in put shaft machined and did a few mods whilst it was apart
Drilled the main oil feed to 12 mm
shaft now done
New bearing coming tomorrow as the front one was ****ed.All new oil seals and drain plug fitted so now like new
wetandwindy2
Apr 2006
19-01-2010, 19:26
did you do all this yourself Andy was it easy to do
46
53
54
55
56
57
58
59
64
