Restoration op Zebra
This topic is closed.
49
50
51
52
53
54
55
62
64
15-10-2009, 11:39
will start to remove engine tomorrow
thought most of it had already made a break for freedon under its own steam.............
pics please
11-11-2009, 17:50
Done a bit today, found out why the box went bang and where all the oil was coming from.
At the start
Engine going to the machine shop tomorrow to be rebored, lightened and balanced
then start painting and rebuild hopefully finished before christmas
11-11-2009, 18:20
so, Where WAS all the oil coming from
Tongy
Jul 2008
11-11-2009, 18:22
Does that mean more nuts bolt and washers on britains highways and byways we have to dodge.
11-11-2009, 18:25
Tongy
why you taken Des out
Tongy
Jul 2008
11-11-2009, 18:32
Proper car DES is, came wiv a sump guard .
11-11-2009, 19:10
flywheel looks in good condition
11-11-2009, 19:17
should be, its renewed after every outing
11-11-2009, 19:27
are you hoping to lower the car even more when the front struts rust through and drops to the ground ?
paul andrews
Apr 2004
11-11-2009, 19:49
thank f ook for that,mandys phoned me 15 times today to tell me the gearbox has no oil in.knobber
11-11-2009, 19:54
paul andrews
11-11-2009, 22:25
Are those engine mounts on the right way?????/
11-11-2009, 23:02
16-11-2009, 14:32
Started the engine strip today . The crank needs regriding so more expence
Oldbloke
16-11-2009, 14:42
Was the Blackberry in there as well? Perhaps that was where the rattling was coming from?
CH
R
i
S
49
50
51
52
53
54
55
62
64
