well failed the mot on friday, needs a bit of welding on the floor and the front brakes effiency is v-low, dunno if the piston are sticking due to only having done 173 since last mot.
Mind you she drove a lot better on the 8 mile trip to the mot station now theres no air leak and the 45's sounded lovely
Gonna get her sorted on monday and hopefully mot'd asap then enjoy her
dont worry yours wasnt the only mk1 to fail its mot on monday
i made up a little bracket to hold the fan stat in. bolted it to the top rad bolt then cut a small slot to go over the sensor . small l shaped bracket. then a bit later i brazed the hole up!put the fan on a switch inside the car.
