some more pics underneath , starting to see the light at the end of all the scraping, some welding to get done next, hope you like the washers on the u bolts
the thread for the tranp bar has disapeared into this hole
looking good taffr but why 4 nuts on u-bolt..??? dont you trust your own work ...
they are my home made washers, it was quicker to do up, as the originals snapped when i tried to get them off, its just a temp measure while she sits on there, saves a lot of wrist action
looking good there graham, that captive nut will be a pain to sort.
the plan ........ make small plate with hole in center, weld correct nut onto plate , then weld plate to chassis with the nut in the correct position , hey presto better than original, wot you wreckon ?
