Originally posted by ASHLEY
Started at Last
Just a quick update to keep you all going.....
The bonnet as been take to bare metal and a coat of primer applied.
Front panel is now fully welded and painted.
New nut have been fitted in the chassis rail for the x member and under wing pans taken off ready for new ones. Kick panel area cut out ready for new the panel when i have finished fitting the tags and cut out for the plug.
That all for now....Andy
CheeRS Joe, Graham. Got some panels, Still after the under pan cups/ uprights and those bits that fit the bottom of the upright. The pieces that fit to the wing rail and cup. Got strut tops of johnylock if the ever turn up.
Just trying to get the underside sorted so i can get the underseal / paint on and give you your jig back Graham...Didn't think it was going to take this long.
Andy
Just a couple more, one of the bonnet.
Now the kick panel is fitted. With a new wing rail at the top and the cut out of the wiring plug made and fit. Then next will be the full wing rail and the top plate or pan. Depends on which panel, I find next
All comments welcome...even if you think its S***..
Comments keep the blues away
Andy
Thanks Lads.
Graham, Cant wait for that side of the build. Put all the new and shiney parts back on. Put a door catch on(other small part) and it looks like you have done loads.. Looks like the mex will be ready for the lakes this time...Andy
... Just found out Lee ak - wozzy, is mate owned the car back in 1984......you just can't have anything on here
