YUE's Engine is out at last!
Ive got one on OUH and found that the sender wouldnt work unless it was earthed to the body (plastic tank)
Originally posted by Nelly View PostNot really Ian, it has had one fitted before by a previous owner (although it just had the standard tank fitted when I bought it), so all the holes for the straps were in place. The standard rubber filler neck is just a touch too short though (bought a new one from the MKII Club). When I bought the tank a few years ago (thanks Leon!) it came with a longer filler neck, which looked like it had been made up to fit, but when I pulled it out of storage, I found its starting to perish, so will probably buy a bit of black hose the right diameter and cut it to suit.
My main concern is if the sender units still working, as i've not tried it yet. I'm presuming that these are the same as the ones fitted to a standard tank??? If I need to get a new one.
Leave a comment:
Leave a comment:
Originally posted by Nelly View PostThanks for the comments guy's.
Trouble is Ian, by the time it's finished I probably won't be able to afford to fill it!!!did you have any probs fitting the tank ??
Leave a comment:
Leave a comment:
Gonna be stunning when its finished, nice to see a 69l in there,
Leave a comment:
Got a bit more done this weekend, big thanks to "Sparky" Greg for sorting out the electrics and the monster cable for the battery in the boot.
The exhaust was right b*tch to fit!! But got there in the end, yes it's an Ashley system........... I know! Had to improvise the back box mounts to stop it fouling the rear valance, and had to cut about 2 inches off the middle section in order to stop the back section catching the tramp bars, but hopefully when we fire it up it should be ok........
Just got the brakes, fuel lines, fuel pump, and interior to sort out now.......!!!
Leave a comment:
looks good mate, u know where I a am if u need another pair of hands mate. Will ring u in the week, got wind of a motor that may interest you for very little money!!!
Leave a comment:
Originally posted by Nelly View PostWill be a bit boring following your trailer all the way up to Cumbria Kev, might have to meet you there.............. Unless, you don't mean............. that your actually gonna drive it!!!......... Go on, you know you want to......
"Might" drive it there but weather dependant.
Leave a comment:
Originally posted by Frosticles View PostGonna be 2 YUE's together......... Go on, you know you want to......
Leave a comment:
Originally posted by GAZ W View PostAs long as there is'nt 2 YUE 477's together...well you never know, what with these mk2 v5's now days
lol
Leave a comment:
Leave a comment:
