looks good
HGD 216T Rally rebuild.
 Thanks for the comments so far.
 Thought about making up my own reinforcements for the pan tops but ended up sourcing a set from Auto Insight.
 Once welded in should provide some extra strengthening.
 Inner wings were given a coat of anti rust primer, high build etch, Stone chip paint and beige primer before the diamond white paint went on.
 New wing tops were blended in with a skim of filler and brackets for strut brace migged in.
 The inner wing tops were from expressed steel. When i ordered them i was told to expect 3 weeks delivery but they arrived within the week.
 The fitting is fine as quality is good, seems to follow the shape of the inner wing really well.
 I dry built everything up around the top and also cut a strip of metal and placed along the top corner of bulhead as can be seen in photo.
 For me it helped to get a feel visually on the alignment but i picked several points from chassis rail to wing top along the length to measure against.
 The angle to the outer wing is the part i questioned many times as i was mating up the tops to Hadrian panels that certainly had differences in comparison with previous panels.
 I also made up a cut out for a new radiator xmember and welded in a set of bolts from underneath so the oil cooler could be mounted. Saves fiddling about with the bolts and them dropping down at a later date. Did the same with the bolts for holding the radiator in.
