A little winter work is now complete, fitted the new axle supplied by Tom at Fostek, highly recommended if someone is looking for work on an axle for either track or rally use,
Full spec T/T Floating axle with 5.1 CWP, motorsport ZF etc....
Also fitted the new miniltes ( as the car did run blue wheels on the gravel sections of the 77 RAC)
Special order from minilite, had a nightmare when they arrived, they would not fit!!!!!! rang Don in a panic, they had been supplied with a faulty batch of inserts.
Also fitted the new all steel, dry sumped pinto.
Done a little work in the dash, namely a new clock pod supplied by Ralloy, superb part fitted as direct replacement.
and a new centre console (Prepfab)
Just the new polycarb windows and will be ready for the lanes of Cumbria!!!!!
