engine head :
2.1 pinto kitcar engine
full port polish head (stage 3)
45.5mm - 38.1mm valves (stage 3)
Kent cams rc31 race camshaft (336 deg. 4000-8500)
Kent cams duble valve springs
Kent cams valve guides
kent cams followers (long pad)
Kent cams spray bar
Kent cams adjustable alloy cam pulley
Kent cams timing belt
Weber 48's dcoe carb.
Ngk spark plugs (ap9fs)
BLOCK :
Cosworth crank
Cosworth rods (with polish)
Vandervell bearing
AE forged pistons and rings (for high kompresıon)
Kent cams oil pump
Aleminyum sump
Short block
Electronic distributor kit
oil cooler
4+1 exhaustmanifold
racing flywheel
ap racing twin plate clutch
roket gearbox
13.1 compression and 210 hp
Kent cams spray bar
BLOCK :
Cosworth crank
Vandervell bearing
Kent cams oil pump
Aleminyum sump
Short block
oil cooler
4+1 exhaustmanifold
racing flywheel
roket gearbox
