as bin grafting lark,you mist me crack ,when i pm you thee tells me to **** off,so wats thee on about lark????
tell thee wat pm me thy nimber if thes mist me that much
thats wat ive been doing choppin and scrapin big brass at the mo kid
thy should weigh that piece of shite in and stop wastin good steel
scrap has doubled in price no the wonder he,s been busy pm me phil i,ll give you his number
Firstly the heater bubble was fixed in a couple of places then protected inside with a rustproof paint, also the area the bubble hides, then the bubble was fitted.
All the paint was removed from the bubble and the surrounding area
A repair was needed to the corner of the fuse block mount, i found an ideal formed section cut out of the old inner wing, its the area where nosecone bracket goes, so i cut it out and used that.
Now welded in.
Finally a couple of pics finished and in Etch primer. Next job is to fit the donor inner wing which will be done soon.
