rolling roads
  • rolling roads
    took my shedy mk1 to a rolling road near salisbury today, for a check up for coombe track day. it made 157bhp. just all been rebuilt by brettly. real high spec, standard rod's and piston's with new ring's, lightened,balanced etc, with a ht head and holbay cam.
    nice one rich, what did they charge you and how did the car drive afterwards m8
      thats good richy, nice one
        £50.00+vat per hour, tick's over like standard and drive's fine.but it has still got a tiny flat spot just before it get's on cam.said it would not be worth the time to fix as it could go on for age's. set up rev limiter and could also compare speedo with correct speed.tried timing up and down etc, which moved the power a weeny bit up or down. slark speed racing is what they are called.
          is that at the flywheel or the wheels
            what do you think
              that is good useable power, what was the torque ?
                199Lb torque
                  nice one richy- was it as good as sigma ?
                    Originally posted by richy c View Post
                    199Lb torque
                    fair play, I reckon that torque figure will make it a real puller of an engine
                      what do you think
                      flywheel ?
                        umm i've had this engine since 1992, just that it need new ring's, some bearing's, valve spring's and 4 valve's same cam.
                          Originally posted by grum View Post
                          flywheel ?
                          oh ok i'll say it, AT THE WHEEL's
                            yep good bloke, more modern equipment etc. but nothing wrong with pete at sigma.so the same really.pete does it more by ear this place by readout's
                              that's great figures richy nice torque to
