I've started..what have I done???
    Reference those spanners kieron, can I have them back please I've been looking for those for ages
      do ya want a hand with this
        mr bishop he said hes taken pictures so he knows how to put it all back the way it was,including spanners and sockets
          ok , haven't had a nice bbq since the lakes
          a few more hours today, decided to cut the battery tray out as this was welded in the spare wheel well as going to mount the wheel back in there.
          No rot under it was a surprise as thought it would rotten with the battery acid and norm waer trap.
          looks worst as got a bit of surface rust, all that waxoil works then.
          all the boot wire-loom ready to be pulled though into the main part of the car but need to label it up first.
          Fuel pump off along with the prop-shaft.
          Did find a pdi sticker so the rear panel is the original one so might patch it up rather than replace it
          Thats it for this week, need to tidy the garage up and start boxing all the parts up so I don't misplace anything
          my_car_in_the_vBGarage
            hi
            u have a wee task there m8 but am sure u will get there .
            keep up the good work and wee all
            like to see pics of ur resto going on ....
              Did a wee bit more today, finished stripping the front and under dash wire loom.
              Thank god I put labels on all the wires and connections, just need to pass the rear section into the cabin then I can remove from the car and fully check the loom and replace where needed.
              Bulk head seems not to bad
              Norm bits of rust around the heater bubble
              so that will be coming off as well soon
              All the "little" jobs take so long, running out of room in my garage fast for all the bits so might have to look into renting another for all the parts
                you will get there K keep at it
                  This loom does look worse than it is due to the additional wiring that has been added for an alarm or something.
                  Your doing a great job and remember Badnews' advice....it's a nice interesting thread this and so many of the usual Escorts problem areas are highlighted here.
                  Tim.
                    Tim.
                    Thanks for the kind works
                    Lots of wire has been added in the last 30 yrs, so once the looms out of the car I will strip out what is not needed, replace/repair where needed and clean it all up.
                    Just going to take my time on the bodywork and repair as I go once car is stripped, do a small section at a time.
                      Doh!!
                      should read
                      "Thanks for the kind words"
                        looking good mate, ref boxes i had a chat with the local Halfords manager and he lat me have some of their delivery boxes they get in. great for storing & stacking
                        AKA The Dipstick
                          wiring is the easy bit son
                            Give me a head gasket any time
                              coming on mate, good luck with it
                                Getting there Kieran
                                Martin
