Thought i would let some of you how i am getting on...the other and you know who you are can kiss my helmet.....
The spiggot bearing in the crank callapsed - taking my box and prop shaft out....
SO i have had the Box fixed, new drop gears and shaft Cheers Gearboxman
I have had a new propshaft - cheers RACE
Fitted some poly bush's on my watts linkage as they were fooooked after 3000miles LOL....
Other bits i have sorted....
Getting rid of the genunine rs500 cooler cause its a myth they are any good - this is forsale if anyone wants it - New custom cooler comes next week.
New water Injection pump and tank goes in this week.
New fire extinguisher goes in this week.
New fuel pump needs fitting, so i have 2 grp a pumps feeding the rail so number 1 has the same fuel as number 4 with a central off take for tha regulator...So 4 fuel pumps in total LOL....
I have also got some new rims for my slicks....same as the tango mk1 of lee's 15x8j Comp ML's
Got a new steering rack to go on to try and help my judder, if that doesn't work then its new hubs for the front with larger bearings than standard..
New engine loom to go in before national day too....
Also got all the bits for power steering but not got round to sorting this yet...maybe done in time for the winter track days....
So all in all been very busy and got loads more to do
