BDA engine (and car) with a twist
  • BDA engine (and car) with a twist
    Some "strange" (as in non-std) things about this engine but also car.
    What are they??
    Odd spot for the dizzy
      ZF Gearbox Mount ?
      No front ARB ?
        Never seen a belt driven distributor like that before. Also those strange links from the TCAs to the chassis legs. Things must have changed a lot on Escorts since my day!
          Compression struts, explains why no anti-rollbar. A common fitment for works competition cars, seen more on stage rally cars, my mates ex-works Escort has them.
          I have seen belt driven dizzys on BDA engines in some historic F2/F3 single seater race cars.
            All of the John Wilcox BD series engines that have distributors have them mounted in the regular place in the block. There are two versions of belt driven mechanical FI - one drives off the cam belt between the pulleys via a cable drive to the rear or this one . . . http://www.wilcoxengines.co.uk/image...h%20border.jpg
            The ebay one looks like a bad interpretation and could be faked? Why do it, what does it achieve having the dizzy there?
              seen them with the injection pump on top of the cam cover
                Position and drive of distributor is very odd indeed.
                Compression struts are used on a few tarmac cars.
                What about the camcover with oilfillercap on a drysump engine.
                Anything else?
                  No dustshield between block and bellhousing (you can see flywheel).
                    Anything else?
                    I can't see a problem with oil cap - putting a gallon of oil in the engine pre cranking is no bad thing - better than cranking for 30 - 1 minute to move oil from the boot to the cam bearings. Lots of cars have no dirt shield - not recommended but not unusual?
                    Thing is its sort of all there just in unusual places / order - enough to risk £15k on though?
                      On a 2nd look - the open bellhousing / dirt / gravel scoop doesn't look like a good idea! The dry sump, sump isn't doing it any favours either in the protection stakes!
                        Anything else?
                        I think the early BD engines had this type of cam cover
                          I have never had a car with said plate but there again the sump gaurd went back enough to cover the scoop
                            Engines with wet sump have a fillercap on camcover, dry sump engines normally have this opening welded shut or don't have it at all.
                            Did you see the lowering blocks for the x-member, so that it clears the sump?
                              I have never had a car with said plate but there again the sump guard went back enough to cover the scoop
                              I never had a car without the plate! Stone getting in there and jamming the clutch wouldn't be fun.
