English Diff Rebuild
  • English Diff Rebuild
    During The Welsh Tour 2010 I shot the bearings in my axle
    Well finally today I managed to get to Fast Track Bearings for a "rebuild" kit to sort it out.
    I have already stripped inspected and rebuilt the LSD unit and set up the pre-load and ramp angles then lock-wired the lot together
    Crossflow flywheel bolts ?
    Slightly longer...... !
      What side gears you running then ? 22 spline (standard) or 16 /17 spline uprated jobs .
        You cant go wrong with a bit of extra length
        Bog standard shafts and end gears
        Have only managed to twist a couple of shafts
        Am not into the 0 - 60 or goin down the pod so luckily I have managed to survive with an English
        I am eventually going to build an Atlas for it
          Mine lasted with standard shafts with no twisting at all (no grip and loads of wheelspin helps , lol) but i uprated them to 16 spline atlas ones just incase and it's been fine . Not keen on Atlas axles , too fooooooookin heavy and expensive , same as driving around with a bag of cement in the boot !!!
            Standard casing back from being chemically cleaned
            Etch primed
            Painted
            New pinion bearing fitted
            New pinion seal fitted and crush tube on the pinion gear
            Setting the pre-load with a proper old skool tool
            Not enough pre-load yet - needs to be a bit tighter
            More pics to follow
              Back lash set to between 0.13 and 0.16mm
                Top work there , now fit it and try and break it !!!!
                  very good dave, nice detail build,
                  like the old skool pre load tool, as per manual
                    All back in and ready to have a play the weekend
                      The techie guy at Tran-X when I asked his advise on amount of pre-load required said "you will never do it correctly without the right tool" he was impressed when I said I had a pre-load gauge and he wanted the details of the seller because they needed a new one and they cant get anymore - lol
                        dave, for wiring locking to be effective it is best to come from the 9 or 12 o'clock position of the 1st bolt to either the 6 or 3 oclock position of the next one, thus pulling both bolts into a tightening position so there cant come undone.
                        dont mean to pish on ya work m8 but i had many of my wirelocking cut by my trainer and told to do it properly many years ago
                          might need your services soon to do a pinion seal
                            My LSD may need a re-build son.
                              your wire locking is still shonky dave, takes no more time to do it properly LOL
