mk1 freshen up
  • mk1 freshen up
    if you start diggin, you will make holes , we finnally got started
    best be gettin the welder out
    Welcome to my world, my welders hardly been put away for the last 5 months! Looking forward to seeing the resto work should be a nice easy one for people of your knowledge and experience.
      repaired inner wings ,,
      one lesss hole
        mk1 update
        built the legs up, with coil over kit, made some wedges, and put gaz top mount inserts in
        rebuilt the brakes with a spacer kit for vents
        then got stuck in to back axle,, put a tran x english in on a 3.54 crown and pinion, rear disc kit,, axle done with tramps
        also managed to get somr bits or running gear bolted on
        then paneled the front end up,, went on ok,, but wings arnt the best copys ,,that said its all gapped up sweet now
        next step is the motor and box,,
        thinkin its havin a red top on carbs and a straight 5 speed
          keep the pics coming bud!
            Nice work and good progress
              Nice to see you use one of your own rotisseries
                that was the 1st jig i made (about 9 year ago) to start the build on my blue 2 door,, does the job
