My Mk1 Monza Mexico
    a few more bits done
    rear scuttle
    new inner repared
    corner cut out
    panels just put in place waiting on outer post ,
    new flitch panel made just need to cut out shock hole
    next to a genuine panel used to copy from
    more pics to come
      Looking really good
        lookin good ,lot of work to do,so glad your puttin her back to the way it was .
          some mental fabricatin work there fancy knocking me up a few bits !!!
            woa some serious work there pal i am not worried by much but what a task that is. anyway it all seems to be coming together for you and good luck with your project. this is the reason i never botherd with an escort in the uk as it would have been to time consumeing. oh yea i am loveing the choice of colour it will look fantastic so keep up the good work
              Cheers lads, Rob's some operator in fairness. Top notch, called in for a look today and it's coming on well, plenty left to do though!
                great work, looking forward to the next pics!
                  some serious fabricating going on there!
                  looks spot on mate!
                    Some outstanding work going on there mate. I admire you for taking the car on. Your man is a top fabricator thts for sure. I cant wait to see this car when finally she is finished.
                    Naturally Aspirated Power
                    RSOC Member
                      o/s wheel arch lots of filler
                      old arch cut out and new one butt welded in
                      tacked in first , rob gas welds all panels except chassis
                      welded all around
                      looking from inside
                      tank well old repair was just tacked on
                      cut out, you can see the rust that was trapped in between panels that were over lapped over this is why he butt welds panels
                      old corner had at least 8 plates welded in, instead of 2
                      new rear scuttle end made and welded in
                      new new front scuttle corners made just need a bit of finishing and trimming up
                      more pics soon
                        some great work been done there
                          new full inner a post fitted in
                          scuttle end made and fitted
                          top scuttle end made and sitting in place
                          kick panel/bulkhead end and apost outer welded in
                          rear of sill to qtr panel welded in
                          a look from inside
                          o/s inner sill and floor this side had 2 outer sills and 2 inner sills 1 over the other then the inner sill was plated with 4 or more plates when they had rotted though, the front floor had 2 floors and a plate welded full lenth of sill from sill to chassis and 2 cross members
                          filled in hole in inner sill and started making front and rear floor panels
                          were getting there
                            mans a genius m8
                              Got to agree, lots of top notch work.
                              Well done for saving her keep pics coming.
                                looking good,
                                keep up the good work,
                                its worth it in the end
                                escort,s do it best sideways
