And again LOL
  • Originally posted by YOD4 View Post
    Think you need to have a word with yourself
    Fuel pump in boot, LED dash lights are you seventeen
    Thought you entered concourse not max power comps, where you going to mount the bass box
    Should look something like this after the work is done...
    • Originally posted by TimGR View Post
      Cheers for the pic, Will use that for reference.
      • Bit more done. All plumbing now done, Fuel pump moved to under the boot floor. Pedal box cleaned, painted and re-fitted. A Dave O Neil Linkage plate fitted, Filter King fitted and set to 3.3psi. Filled the tank with some Tesco 99 RON petrol as I wanted to have a quick go at starting it. Turns over but not that quickly......(Tight engine?) Didn't start so advanced dizzy slightly. Car backfired so at least that's something LOL. Will have another play tomorrow.
        • kev, pump should be mounted to floor via the 2 little rubber bushes.
          might vibrate itself to bits otherwise.
          looking good though.
          • Originally posted by Mark M View Post
            Put the bobbins on but the pump sat way to low. When I first switched it on it rattled the whole car till it primed then quietened down "A little" LOL
            • Originally posted by Frosticles View Post
              why was it too low. were you worried it may catch on the trailer.
              • Originally posted by richie View Post
                There is the possibility of that......:winka:
                  or the Gravel......................
                  • looking outstanding kev well done
                    ya co ck
                    • Finally finished the engine bay today and am very pleased with it. Just need to put the washer bottle on but am in 2 minds whether to fit a strut brace or not??????? Oh, decisions.
                      Had to chop loads out of the Servo tower for the exhaust clearance and heat shield the brake pipes and clutch cable. Going to get hot I think.........
                      • get the brace on kev, make sure its black
                          engine bay looks amazing. well done mate.
                          • Originally posted by taffr View Post
                            Need an "Inbetweeny" hole one as I have rubber roller tops fitted. Like the look of the one both Hally and Grum have. Agree, Has to be black
                            • modify it properly and fit a bias pedal box......LOL
                              • Originally posted by lee bishop View Post
                                No chance, LOL
