Wedge
    looks good paul, will you be getting it blasted, don't look too bad, quick rub and some primer, what you reckon??
      Looks a good shell.
      Murdo DA
        any more Pic's PR
          Plan is to get it blasted eventually.
          son
            Looks a good base does that . I love a TR8 and would have a Tony Pond replica for sure . Cool as fooooook
              son
              So today, while the sun shone, we did
              I'm not surprised they are so heavy and rust so much, how complicated are they underneath
              You enjoy the pics and I'll be on another site ordering panels ...
                looks great! escort should have been on the spit and triumph on the springfield tyre heap
                  looking good,,,,do love a wedge with a V8 rumble
                  my_car_in_the_vBGarage
                    Blimey thats a solid shell youve got m8, looking good
                      Looks like a good shell m8 better than the few i've seen
                        Nice when you can pick up the phone and order new old stock doors and have them delivered next day , other side next pension day.
                          Had a few hours trying to get the N.O.S door to line up, taking a bit of messing about, need this lined up nice with rear 1/4 and the sill then I can get cutting the sill off and door will be my ref' point for new panels.
                          Hope I don't get the parts mixed up
                          son
                            when will this be ready for karlos to paint,he is really looking forward to it
                              when are the BIG arches going on ? - thats all we want to know about
                                Had a couple of hours today on the shell, decided it was time to remove some panels, firstly an exploratory cut in the front wing to see how bad it is and what runs where, knew there was a loom in there somewhere, was quite pleased with the panel behind, again the wee bit of surface rust at the top looks worse in photo, the sill has a couple of holes at the bottom and front but this is to be replaced anyway, inner arch has expected rot where it meets the wing, again I have a new inner tub ready to go in, nose panel where the 4 bolts are is perfect. Also removed lower rear sill, not impressed with the pattern repair panel, will need some work to get a very good fit, seems too long. Had to stop for a while as there was a show on locally and the last remaining flying Vulcan bomber was buzzing the unit, awesome sight and sound
                                cheers, Paul
