English Diff Rebuild
  • #31
    nice pics there mate that wil be a help to me as im going to rebuild my axle soon but need to decide wether to uprate halfshafts or not, i think i will make the decision when i get them out & inspect them. cheers.
    • #32
      Originally posted by RS2000CUSTOM View Post
      Hey Dave,
      I like what you have done with the lock wire. I removed my diff today to find the crown wheel bolts have worked loose.
      I have sent you an email.
      Paul
      • #33
        Originally posted by Paul View Post
        Hey Dave,
        Paul
        Mine unwound itself at oulton park last year, and proceeded to shot itself at the time..
        Well worth lock wiring when complete
        • #34
          Cheers Louie,
          I am hoping Dave will be able to lock wire mine and rebuild the diff.
          • #35
            Dasadrew
            • #36
              Nice description!
              I'm just winding up my diff overhaul - did it by the book but am surprised with a couple of things - need an experienced opinion!
              As I haven't renewed the bearings (did that a couple of hundred miles ago, but then had an oil leak), I set up the pinion to about half the book setting, and have now just set up the backlash. Was an effort to crush the spacer - ended up using a metre extension bar on the socket.
              Playing with other older diffs I have lying around, they have loads of play in all directions (pinion in and out and backlash). If you get hold of them and move the pinion/crownwheel they really do "clank, clank".
              Having set up mine by the book, everything moves nicely, but the play is really absolutely minimal - more of a barely perceptable and hardly audible "click, click".
              Setting up the backlash, I really had to exert effort to tighten up the adjustment collars. On the old diffs, they can more or less be undone by hand.
              Question: is it really that the old diffs are worn, or am I setting up mine too tight? (I can still turn the diff by hand and it's very smooth - just no longer clanky clanky!)
              Cheers for any feedback / praise / warning what a nutter I am etc.!
              Drew
