axle and gearbox bearings, important notice
  • axle and gearbox bearings, important notice
    if you are about to buy any bearings for you axle or gearbox pm me first and i will tell you who not to buy them from and save you a lot of money and agro
    Buy Timken or Koyo bearings and you cant go wrong
      Or SKF - good rep!
        the bearings in question are skf and have failed prematurely but the company i bought them from are not in the slightest bit interested
          Speculating here - were they a 'saving' compared to others? Seller not being interested - warning sign! There are eastern european / chinese counterfeit bearings around so strongly suspect you've got some?
          Ford English rear axle wheel bearing kit by SKFThis wheel bearing kit will fit Ford English "Timken pull out" type halfshaft fitted to Mk2 Cortina, Escort Mk1, Escort Mk2, Capri 1600, Lotus 7, Kitcars etc. Each kit contains:1 x SKF 62mm OD bearing1 x retaining collar.So two kits are required per axle Every week i receive calls from customers who have fitted the cheap far eastern version of this English axle wheel bearing kit saying their seal by the halfshaft and brakes is leaking and what should they do.We first experienced this type of bearing (often with a rubber O ring on the outer diameter) in 2006 when we sold a few and had them returned for faulty seal issues.I stopped selling them immediately.Unfortunately this high quality SKF version of the Ford English axle wheel bearing is quite expensive compared to the cheap china version sold by many other suppliers, However this SKF wheel bearings value soon appears due to it's extended life and tiny failure rate, in 10 years we have had only one returned under warranty and this had been on a race car.Sometimes the old saying "you get what you pay for" does still apply, whilst not all cheap products are poor quality some unfortunately are, and when you add up the cost of time and labour to replace the cheap type if they fail it may be wise to get the higher quality part in the first place.If you have any questions about this SKF wheel bearing kit or just want a bit of advice please feel free to call me on (UK) 012 7979 3631 and ask for Mark.
            Counterfeit bearings are becoming increasingly sophisticated and are difficult to identify. These fake products can have disastrous consequences.Some compani...
              Follow the Chinese authorities in a raid against a counterfeit bearing workshop. In this video you can see how low cost bearings are branded to look like hig...
                oh that's interesting, thanks lads i didn't realise there were counterfeit skf bearings about, is there an easy way to tell the genuine bearings from the fake rubbish ?
                  For an average "Joe" I don't think so hence why the Police take a SKF tech with them on raids - if bearing suppliers (legit ones who should know better) are either getting caught or are deliberately passing them off as good - what chance have we got! I guess follow the SKF advice and buy from authorised re-seller - quality costs!
                    Counterfeit
                    It can be really difficult for a manufacturer dealing with counterfeit product. Obviously not good for any manufacturer having poor quality non-genuine products being sold as genuine, as even though non-genuine, with the prevalence of social media & forums it is still damaging to the brand. But trying to stop it can be almost impossible.
                    From the manufacturers point of view of trying to inform the general public on how to spot non-genuine items, you also run the risk of informing the counterfeiters on how to make better copies.
                    Really the only advice is to give is, if it seems too cheap to be true then be wary, or as previous poster, only purchase from trusted/authorised source.
                    You could try contacting the manufacturer direct if you suspect fake, as they may ask to be sent the items to check for authenticity. If lucky, they may even replace with new items to retain the copy goods (give them full details and any copies of invoices from seller), but the manufacturer is under no legal obligation to do this.
                    Hope you get a resolution.
                      as you say cheapest is not always best
                        they weren't cheap, two skf bearings for the rear axle came in with postage at around the £100.00 mark from a uk company that lists it's products extensively on the internet.
                        the bearings in question were fitted at my local engineers and had done approximately 1000 miles before they gave up with axle oil getting past them and your typical worn out axle bearing noise
                          fitted 2 to 2 different Axles, April 2018
                          Got the first 1 from my local Motor factors for my own car
                          It was a -FAG one , it had no oil seal - £25
                          A friend bought 1 from Burtons , no name on it - had the Oil seal fitted - £ 25
                          Both seemed good quality , both still going
                          Time will tell .....
                            https://www.bearingkits.co.uk/SKF-Fo...rs-etc/582.htm
                            Is that a link to the people to avoid or a recommendation?
                              Neither - just used as an example of what I expect to pay for genuine SKF! Over the years the amount of words that have been written about how to solve / cure 'newly fitted' leaking bearings is just daft - added o rings, added seals, removing seals, heavy grease etc, etc - when the simple answer is spend the right money for a correct product. Cost your own additional tinkering time out at £10 / hr and those 'genuine expensive' bearings soon begin to look economical!
