My mk1 73 Le mans green Mexico
    thats some amount of work you's are putting into her bet she'll look good when ready not a project for the faint hearted that one
      Hey Glyn, I thought cleaning all the crap and rust off my back suspension was a rotten job ("Time to get those rear springs fitted" mentioned in this section), until I read this thread tonight. It makes excellent reading, so you keep on persevering with this job because you are doing great. You will get there eventually and everyone will want to see it!
      Keep it Going!
      Tim.
        Originally posted by Mr Hoarder View Post
        I'm itching to see the pics of this one WHEN IT'S FINISHED
        On a lighter note : Check out this thread and see if you recognise the background lol
        http://bbs.rallyesportescorts.co.uk/...ad.php?t=22194
        I thought you were all sharing workshops when I saw this thread !
        Keep it going Glyn......it will all be worth it when you drive it ...sometime......in the future.....
        My cars in the VbGarage
          The photos of Glyns car in that workshop were taken in in 2005 !
          The photos of Andy Burtons car were taken this year ! (some today lol)
          Mark and I both had workshops at the same place, I moved into one next door to him shortly before he moved to Australia and Andy Burton moved into Marks old place after he left
          Cheers Rob.
          www.RWD-Escort.co.uk
            That makes it clear now Rob
              Glyn,
              Have you given up again already??
              Regards
              Mark
              homepage
                Originally posted by 2quick4u View Post
                Glyn,
                Yes I think he has lol
                Cheers Rob.
                  leave G alone, he's busy with some calendar
                    ****ing hell Gyln its the 1st time iave seen this thread top man can not wwait to see it finished iave got nowt to wory about well done mate keep at it
                      I'm trying to get the thread up to date to where it is now and I have done a bit here and there recently for all the doubters
                      back to the story
                      the corners of the bulkhead were horrible so Mark cut them off and started making new ones from scratch
                      and new A panels
                      with this sorted Mark started filling in the space at the front and welding the inner wings on, this involved putting the wings/bonnet/front panel on and off several thousand times
                      new
                      with this sorted it was the turn off the other kick panel
                      more to follow
                        Looking good, keep the pics coming
                          A lot of good work done there. Keep the pics coming
                            then it was on to the bulkhead side is welded in and ground down, the wing filler is welded on, and we started making the front radiator/ slam etc. panels fit.
                            rad tried for size
                              then Mark fitted the rad panels and slam panel , then got the wings and front panel ready to fit and drilled some mounting holes so they can go back in the same place after paint .
                              We left fitting the wings and front panel till after we have finished the underside, next stage was to get it on the rollover spit.
                              got another better bonnet at this stage, must say seeing it paneled up at the front made me go a bit squiffy
                              melded up
                                tayysteeeeeeee
