Escort Mk1
  • #61
    Originally posted by escort new boy View Post
    Great project
    Thanks
    • #62
      This forum wont allow posts to be edited - I've just found pictures of the hinges before being welded onto the new A pillar - so I'll just add them here -
      • #63
        Drivers Side A Pillar repair Cont -
        All three panels in their correct positions.
        The splash guard is also fitted.
        • #64
          Due to previous accident the original A pillar was not quite square.
          This was highlighted by the jig.
          Not only were the door hinges in the wrong place but the gap between the jig and the top and bottom hinges were different.
          Before repair
          After Repair
          • #65
            Great project
            Hi looking for a pair off wings to bubble arch have u got any thanks
            • #66
              PM You!
              • #67
                Test Fitting the Doors
                As both a-pillars have been repaired, the hinges will have moved, so before going any further best make sure the doors sit/close properly.
                Drivers Door
                Passenger Door
                • #68
                  The replacement rear tubs have arrived so along with the replacement dash and rear shelf are off for sand blasting before fitting.
                  • #69
                    Inside view of the doors
                    • #70
                      The Dash, axel, rear panel and tubs are back from sandblasting
                      • #71
                        The media blasting has shown up a few problems with the rear panel and tubs which will need sorting.
                        The water gully behind the grills in the rear flitch plate also needs work.
                        • #72
                          The replacement tubs although in really good condition need some work
                          • #73
                            Meanwhile work has continued on the front - drivers side inner wing replaced
                            Just passenger side inner wing to fit then the rest of the front will be fitted.
                            • #74
                              Anybody know what these holes in the rear parcel shelf are for -
                              I thought the middle hole was for a single speaker?
                              • #75
                                Yeah, the round one is for the sub and the oblong ones for the flat diaphragm speakers
                                Yeah, the round hole is for a single speaker AFAIK.
