Out of disaster comes ...more bloody work
  • #61
    Managed a couple of hours on the car today.
    I removed a section of floor over the front leg join and came across this
    The previous owner had fitted a new floor section over this and not bothered doing anything with it
    Rear leg was rotten where it joins to centre section but a little further back its solid
    So managed to get the new section welded in at the front
    Now run out of mig wire doh!
    • #62
      Ouch! Looking forward to seeing the new one progress
      • #63
        I feel your pain serious work u are putting into this dont think id be able for it, keep with m8 has to end sometime..
        • #64
          During the week i managed to get the rest of the floor out
          • #65
            I'm hoping to get the floor welded in this weekend
            • #66
              that last pic is fabulous
              • #67
                Like it grum
                Any idea what panel should be in this gap?
                • #68
                  I trial fitted the floor this morning,marked the area where the chassis rails go then drilled 6mm holes along the length of the panel along the line of the legs then put some weld through primer on the floor
                  Dropped it back in and started to weld
                  It fitted great, no problems at all
                  • #69
                    Also today i got the large diff tunnel welded into place
                    • #70
                      Great progress!
                      • #71
                        Apparently the floor to inner wing panel is unavailable so i had to make something to do the job
                        Once they were in i made a start to fit the watts linkage floor roll
                        Only got as far as cutting it out as i removed all the paint from the boot floor and came across quite alot of rust
                        • #72
                          This is an epic build Mike, I take my hat off to you.
                          I need a few panels to fix mine (nothing like as many as you!) - SD don't seem to have web site but quite a few people sell Magnum, and they seem good, so I'll go for them.
                          • #73
                            Quickly lobbed the O/S inner wing off this evening
                            And came across this triangulation which i have never come across before
                            Not quite sure what it would strengthen but i applaud the effort
                            • #74
                              could have bought my "rs1800" shell .......... less to chop away
                              • #75
                                Got the seat rails welded in
                                And got most of the inner wing to bulkhead removed
                                And over the weekend i hope to get this corner from the damaged shell chopped up and installed into this shell
                                Off work for a while now so it will come together quite quickly now
