Foa Chesney
  • Foa Chesney
    Son dont forget to connect the main power cable to your battery other wise it not start even with jump leads or booster pack
    wise words son, wise words.
      Nobody would do that would they
      Martin
        Chesney - Did you have to ring the MKII RS2000 registrar to get a bit of help ?
          Funny u should say that
              Only 3 hours to sort it
                Don't believe the hype
                  dont believe anyone could make up a story like that, must be true
                    Useless Ginger Tw0nk
                      Johnny doesn’t check radiator hoses are tight before adding coolant
                        Who took the hose off sonand forgot to tell me anyway it was you that got covered in antifreeze son
                          you should have looked son
                            Son your nose was in my way
                              my fist will be soon
